Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Skymaster Large F18
    Received: 977
    Skymaster Large F18
    Woohoo! I started a new project today!!
    Was purchased by Sandro and painted by a guy up near Wingham! Beautiful paint job. Nice airbrushing. Matte finish is superb.
    Sandro sold this to James from Texas. James asked me to get this airworthy before it gets shipped down!
    Will have twin Cheetahs.
    Huge machine!
    Received: 977
    Re: Skymaster Large F18
    First job will be to tear out all the crap SM airlines and fittings. To be replaced with good Festo stuff
    Also... 90% of all Skymaster air cylinders leak around the nipples. Will pull each cylinder out, lube them and will Hysol all the fittings where the threads leak.
ID:	23433   Click image for larger version.
ID:	23434   Click image for larger version.
ID:	23435   Click image for larger version.
    Senior Member Vettster's Avatar
    Received: 43
    Sweet!
    Simcoe Model Aircraft Club (SMAC) Our forum is here.. http://smac.freeforums.net/forum
    http://rccanucks.com/showthread.php?...5596#post15596 clubnomax
    If you do not have the time to do it right, where do you get the time to do it over?
    Received: 977
    Plumbing is all redone with Festo. All cylinders taken apart and the piston orings inspected and lubed up.
    Threaded nipples hysol’d
    Incredible beefy gear on this... reminds me of the massive gear on the SM F14
ID:	23437   Click image for larger version.
ID:	23438   Click image for larger version.
    Received: 977
    Fuel tanks consist of a huge center tank and 2 additional saddle tanks that wrap around the intake plenum
ID:	23440   Click image for larger version.
ID:	23441   Click image for larger version.
    Received: 977
    Fittings will be Jet Model Products XXL with XXL tygon.
    Awesome flow rate and very high quality.
ID:	23443   Click image for larger version.
ID:	23444   Click image for larger version.
    Received: 977
    We’re going with 4 JSP air tanks with 4mm fittings and lines
    2 x XL for gear and doors
    1 x Med for brakes
    1 x Med for canopy and airbrake
    Compared to the 4 small SM tanks, we’re putting about 3 times the air in this.
ID:	23446   Click image for larger version.
ID:	23447   Click image for larger version.
ID:	23448   Click image for larger version.
ID:	23449   Click image for larger version.
    Received: 977
    Steering servo installed.
    Was too tight to install it in the plane so removed the nose gear.
    Unilights coming soon!!
ID:	23451   Click image for larger version.
ID:	23452   Click image for larger version.
ID:	23453   Click image for larger version.
    Received: 10
    Cool 😎.....gotta give credit to Likai, his landing gears are a work of art 👍
    You’ve got about a grand in Festo fittings alone there 😜....
    4mm air line, wow 😮....my BVM/Jetlegend 1/7.7 F-18 uses 2mm... really small diameter but so far seems to work fine bench testing
    Nice work as usual....
    Received: 977
    Ya Eric. Lotsa Festo but so worth the cost!! Loving the Lakai gear. Really nice details and crazy beefy.
