Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 97
Thread: Havoc SS / GTS Triple Build!!
    Received: 977
    Re: Havoc SS / GTS Triple Build!!
    I keep working on control horn installs between my GTS and the two SS’s
    The small sheet is my GTS. The two big sheets are the SS
ID:	23118   Click image for larger version.
    Received: 977
    Rudder horns painted gold for Sandro’s SS
    Red for Frank’s SS
ID:	23120   Click image for larger version.
ID:	23121   Click image for larger version.
    Senior Member thaley's Avatar
    May 2017
    terry h
    kingston
    spectrum
    Nice. is everything pre hinged?
    TreeD - Rainman
    Received: 977
    Yeppers... prehinged
    May 2017
    terry h
    kingston
    spectrum
    that sure saves time when doing 3 of them.
    Received: 977
    Stabs/elevators are pretty much done on the 3
    Horns painted and hysol’d in place
    GTS
    * MKS747 servos, 1” metal arms
    * Ball ends and metal links included
    SS
    * JR S8911 servos, 1.5” metal arms (should arrive soon)
    * Ball ends and links not included
    * Dubro HD ball ends
    * 2.5” Ti links
ID:	23150   Click image for larger version.
ID:	23149   Click image for larger version.
    Received: 977
    So I got these MPX holders from AeroPanda. Experimented on my GTS.
    Turned out great. Nice and clean and no chance of wires falling into the fuse or dangling close to the pipe!
    Will do the same on Sandro’s and Frank’s SS
ID:	23154   Click image for larger version.
ID:	23153   Click image for larger version.
ID:	23152   Click image for larger version.
    Received: 977
    Also did the same with the Thunderbolt quad-connector for the wings (aileron/flap/gear/brake)
    Milled a slot for the TBolt connector, glued it in place
ID:	23156   Click image for larger version.
    Received: 10
    That’s slick Trev...
    Senior Member Daren71's Avatar
    Daren
    Mississauga, ON
    Received: 19
    Given: 179
    I like those MPX connectors. If your wing or stab was flush mounted, would they still work with the black mounting sockets?
    Thanks, Daren
    Hey Daren. They will only work if there is a recess or cutout in the root of the surfaces
