Thread: Ziroli 77 inch Stearman 1/5 scale
    Member BJH424's Avatar
    Mar 2016
    Brian H
    Dundas
    Jeti DS14
    My Location: Dundas L9H4V5
    Model Number: PT17
    Manufacture: ziroli pla
    Asking Price: $1300.00
    The is a Contest grade built Ziroli Stearman painted in RCAF colours which I purchased built in 2018. The workmanship has to been seen to be appreciated. Note the rib stitching, rivet and hinge detail. I installed all new Savox servos , a new DLE 35RA with less than 1 hour running. Frank Tiano Dummy radial engine and cowl were added. This model has been flown 6 times and is perfectly balanced. Its very easy to fly and handles main wheel or 3 point landings with no problem. Like all Stearman it likes grass better than asphalt. Robart scale gear with spring oleos. The vertical performance with the DLE 35 is impressive.
    The model has full length spars in each wing and does not need the flying wires to fly. The flying wires are for static display only. It assembles in less than 8 minutes. Easily transported in a small car. Custom wing covers included.
    The Ziroli plans are included. Never damaged and is in mint condition.
    Asking 1300.00 or best offer. Just add your batteries and receiver and go fly.
    Have to make room for my next project so this beauty must go.
ID:	22421   Click image for larger version.
ID:	22422   Click image for larger version.
ID:	22423   Click image for larger version.
ID:	22424   Click image for larger version.
    Money generates lift.
