Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: AR Smoothflite RRS
    Received: 966
    AR Smoothflite RRS
    Was gonna pick up another Mercury but read a few neat reviews about this unit.
    Some cool new features that it has (on paper) so decided to give it a try.
ID:	22186   Click image for larger version.
ID:	22187   Click image for larger version.
    Received: 966
    Re: AR Smoothflite RRS
    3 options to turn this on...
    Base - pin and flag
    +$30 - magnetic switch
    +$35 - key fob
    Got the key fob. I will lose it. Bad decision. Will order the magnetic switch
    Received: 966
    Features that intrigued me to buy one...
    * no need for GPS for gyro gain adjust... automatically adjusts gain in a different way
    * all ports can be set for gyro output
    * 15 point servo matching for things like 2 aileron servos
    * colour touch screen
    * telemetry
    Will see. May be just hype. To me the Mercury is the gold standard but it too has a few drawbacks
    Received: 111
    Given: 12
    OK so its Power Distribution Panel with a built in gyro that doesn't need a GPS?
    Must be a JET thing!
    Received: 966
    Going in my 104” AJ ARS. Flew it last year with a Mercury. Eager to see how this performs
    Got the ARS base setup done last night. A few pros and cons so far...
    Cons
    * there’s no selectable orientation for it like Jeti Assist, Mercury, iGyro, Aura, Cortex. It needs to be installed front-back, not sideways
    * when setting up the servo subtrim and endpoints, each push of the button is a course movement - wish the movements were more fine like the Powerbox
    * it would not recognize a Jeti REX 10 receiver but would recognize the standard recievers (non-REX) no problem. So currently have 2 R3’s connected to it. Might be me. Need to look into that soon.
    Pros
    * love the colour touch screen and so far much easier logic to navigate and program than a Mercury
    * awesome 15-point servo matching. Set subtrim and endpoints like a Mercury but then finetune with 15 point matcher. Very impressive
    * assigning your Tx channels to ports is super easy... all graphical. Love the layout.
    Will get into the Gyro setup tonight
    Senior Member wingburner's Avatar
    Dec 2016
    Ch*nt-Free
    The Hut
    Received: 166
    Given: 375
    Going in my 104Ē AJ ARS. Flew it last year with a Mercury. Eager to see how this performs
    Cons
    * thereís no selectable orientation for it like Jeti Assist, Mercury, iGyro, Aura, Cortex. It needs to be installed front-back, not sideways
    * it would not recognize a Jeti REX 10 receiver but would recognize the standard recievers (non-REX) no problem. So currently have 2 R3ís connected to it. Might be me. Need to look into that soon.
    Pros
    Cool Trevor, I bought the version without the Gyro as they weren't available yet. Like you say it's a bit different but I think overall a great option to powerbox. The remote FOB is cool and works great. I found the setup fairly straight forward.
    Look forward to the rest of your review with Gyro setup.
    Received: 966
    So scratch off the con about the adjustment steps being too course.
    First setup subtrim and endpoints in the AR - this has a course adjustment.
    Second use the 15-point balancer - this has a fine adjustment.
    Makes sense.
    Received: 8
    For anyone that might care about using Jeti with 900Mhz receiver back up as well......from another forum:
    Originally Posted by Viper1GJ View Post
    This is my question also, specifically can or how does it handle, or can it handle both 2.4 and 900 mhz from the Jeti DS-24. So far I can't find any info about this. The system looks real good and is lots cheaper than a CB400 and CortexPro.
    Gary
    gary I just asked the engineers. Here is the reply
    Hey kris.
    Hows it going buddy?
    Yes you can use both the 2.4 and 900 receivers. What you can do is run 2 x2.4 rxs and then connect a 900 to the back of the primary 2.4 rx.
    gunradd is online now Report Post
    Received: 966
    Gyro setup... so easy to setup it is kinda worrying me, LOL
    1) Run Gyro Wizard - 2min
    2) check gyro direction and adjust - 1min
    3) stand around and scratch your head why all gyros are not this easy - 1hr
    It has 2 modes...
    VCG (variable gain control) where you adjust gain with a knob or mix with GPS if you want
    OR
    AGC (Automatic Gain Control). So no need to mess with gain. Instead of a GPS to increase gain as you go slower, this unit senses the start of gain flutter and backs the gain off. So theoretically it is always optimizating the highest gain for any condition.
    Skeptical that AGC will work as advertised.
    Will see. Eager for a bunch of flights
ID:	22192   Click image for larger version.
    Senior Member Bgelok's Avatar
    Brad Gelok
    Kingston, On
    Received: 40
    Given: 27
    Huh....sounds good in theory. Make sure to get a video of the first flight with it tho, you know, just in case it works
    Gimmie the sticks, Iíll fly it !
