Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Hostetler 30% Chipmunk
  1. #21
    Senior Member rpm's Avatar
    Paul M
    Today
    Woodbridge, ON
    Futaba 18MZ, Jeti DS-16
    Received: 56
    Given: 58
    Re: Hostetler 30% Chipmunk
    Great looking oleo struts!
    Humber Valley RC Flyers
  2. #22
    Senior Member Ramjet's Avatar
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Thanks Paul, I used 7075-T7 so I won't have to worry about them bending , They are massive, the outer diameter is over 1" . Anyway managed to find time to make the upper pivot clamps ..
ID:	22237   Click image for larger version.
  3. #23
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Finished the landing gear . can't believe what they ask for these thing ,only takes a couple of hrs to make them by hand ,and $30 of material I had laying around .I think I should sand blast the oleo joint to make it look more like cast .weight is 9 oz each and have 2-1/4 inch travel ..
ID:	22239   Click image for larger version.
ID:	22240   Click image for larger version.
  4. #24
    Senior Member flyloose's Avatar
    Feb 2015
    Eric R
    Today
    Barrie
    Jeti DC-24
    Received: 8
    Given: 1
    Nice job on the gear struts 👍
  5. #25
    Senior Member
    Jul 2015
    Orval Altwasser
    Yesterday
    YellowGrass, Sasatchewan
    Spektrum , FlySky i10
    Received: 21
    Given: 4
    That’s going to be a sweet airplane Roger, especially with that motor. So cool! You must have your own lathe to be cranking out beautiful struts like that. Wow! What kind - size lathe you got ?
  6. #26
    Senior Member tbrum's Avatar
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 967
    Given: 745
    Really coming along nice Roger! Huge congrats
  7. #27
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Thanks guys , these are the machines that do all the work The mill is a full sized Millrite , forget what size the lathe is I think 14"x 48 ""added digital readouts to both . the readouts on the lather are for a wood working lathe and are quite inexpensive but work very well ,down to .0005". Next I will be sheeting the fuse ,not sure how to go about it , such tight curves and the Balsa they supplied is like maple LOL. even after replacing all the Balsa,1/8" is pretty thick for those curves ., I am thinking about using balsa 1" strips . Has anyone tried doing sheeting that way . cheers Roger ..
ID:	22279   Click image for larger version.
  8. #28
    Senior Member
    Jul 2015
    Orval Altwasser
    Yesterday
    Received: 21
    Given: 4
    Beautiful shop tools Roger. Your work shows me that you’ve got great tools and you know how to use them . I have a Force 14-40 lathe ( cheap Chinese knockoff ) but it works great for all my farm machining and hobby stuff I have to do . Would sure like to buy a milling machine too , but alas , it’s tuff on the farm , ha ha . Really enjoying your build so far.
  9. #29
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Orval ,I'm sure the tools are a lot more capable then I am LOL. but it's fun trying , after a few yours you start getting a few thing that actually look like something..
