Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: update on a redundant onboard system
  1. #11
    Senior Member itizme's Avatar
    Steve W
    Yesterday
    Angus
    Futaba MZ, Futaba SZ
    Received: 210
    Given: 73
    Re: update on a redundant onboard system
    The gyro will allow you to fly in worse conditions, makes landings a bit safer. Other than that they do clean up some of your maneuvers but only on the axis you are not puting an input into.
    If you want very basic power distribution you could go with a smart fly
    Futaba s-bus uses the servo to decode and that's why you can run one wire to a hub. I think most of us
    prefer more wire than less wire for current. Powerbox bus system uses larger cable and allows any type of servo plugged into a hub that does the decoding
  2. #12
    Senior Member flyloose's Avatar
    Feb 2015
    Eric R
    Today
    Barrie
    Jeti DC-24
    Received: 9
    Given: 1
    Quote Originally Posted by itizme View Post
    The gyro will allow you to fly i worse conditions, makes landings a bit safer. Other than that they do clean up some of your maneuvers but only on the axis you are not puting an input into.
    If hou want very basic power distribution you could go with a smart fly
    Futaba s-bus uses the servo to decode and thats why you can run one wire to a huh. I think most of us
    Prefer more wire than less wire for current. Powerbox bus system uses larger cable and allows any type of servo plugged i to a hub that does the decoding
    Well said...
    Hi Steve
  3. #13
    Junior Member Beaublus's Avatar
    Sep 2018
    Loic
    France
    Received: 1
    1 Not allowed!
    Thanks for the update. I can see things clearer now.
    So I think I will go for the BLS172 package sold on RCjapan.
    A Booma expander with 2 Futaba receiver
    2 batteries : 2S 4000 mah
    a Ultra Ibec
    and I will be ready to roll!
  4. #14
    Steve W
    Yesterday
    Angus
    Received: 210
    Given: 73
    Sounds wise
    Cheers
  5. #15
    Senior Member
    Mar 2015
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Received: 9
    Given: 1
    1 (100%)
    Quote Originally Posted by JBajkor View Post
    You need to check this out: https://www.frsky-rc.com/product/redundancy-bus/
    Connect 2 batteries, 2 receivers with one SBUS wire each. This is an expander using redundant batteries and Rx. It will monitor current to each servo and shut down any servo that seems to be stalled. Amount of time and current for servo shutdown is in the specs. This is a fraction of the cost of PowerBox products! I don't know why more people are not using these????
    I have been using these on my jets for a couple years now Joe. They are really good for FrSky systems. I am sure that they would work just as well with Futaba as they use the same SBUS protocol. Direct copy of the Jeti stuff, and the new version is even better for high amperage draws. I feel a bit bad that it is such a knock-off of the Jeti, but it does work well!
