| Received: 214 Given: 74 |
The ignition is as easy as on and off. My norm is to just use the gear channel and assign to whatever switch I like. Wiring as simple as from receiver ( powerbox in this case ) to ignition. No need for a switch.
Doesnt matter where you match your servos so long as you teach the endpoints after you are all set. Not sure on the mercury but on the 3e there are two procedures for this. One you push the white button or two is to connect to the terminal software, likely number two works on the mercury.
| Received: 11 Given: 1 |
| Received: 63 Given: 154 |
Okay, ya would be waste of money I guess if I wasnt to use the gyro and gps functions, main reason I ask is because the mercury servo match is so limited, center and end points only. There can be binding all the way along the travel and it doesnt allow for any adjustment between the end points.
Dean.. a couple things...
Setup Wizard... this makes life so easy. Just follow the prompts and it’ll make you wiggle sticks and switches and will do the mapping.
Ignition... say you have ignition as ch7 on your Tx. Just go into the mercury mapping and assign a spare port as “direct7”. Plug your IBEC into that port and test
Servo marching... center and endspoints has never failed me yet. You’d have to have your servo geometry really messed up for it not to work. Tons of adjustment. You’ll really love the feature how it holds 1 servo while you adjust the other.... very user friendly
Okay thanks will give that a shot with the ignition. I think some of my frustation came when I went to use it as gear channel and now I'm getting that door sequencing message everytime I flip on and off the ignition. I will clear all that and start over.
As far as the end points ya I 've had some horrible geometry on some arf's like the aeroplus 111", using the multi point servo matching feature I was able to keep the amps and binding low throughout the entire travel. I know EF has different sized control horns on their planes to allow for better geometry and Will suggested I use different holes on the laser to get closer.
Will setting up ail differntial in the transmitter mess with the mercury and gyro settings?
You are way better to setup center and endpoints in the Mercury... makes a difference later when you start setting up your 3 gyro flight modes and start having different surface mixes for the different flight modes.
I had setup a couple with Tx tweaks then got to this stage and had to go back and do it in the Mercury.
Okay update
Did factory reset, went to set up assistant, following along everything good until assign f-mode switch, it will not recognize my switch which I have assigned as SD under function assignment
I assume if I can't get it to learn that switch then I have no chance in hell it will learn the gain slider
Obviously I am doing something wrong with my transmitter as the PB will not learn from it
Burning midnight oil here LOL and I figured it out. Basically transmitter was not sending signal out for gyro switch, gain or ignition switches I had assigned.
After assigning each switch a function in model-function assignment then you have to go into -servo assignment
Once in there all I could see was the basics, throttle, ail, ele and rudder, for the hell of it I hit the AUTO button and BINGO all three functions I had assigned previously were populated and working
This is a function of the Jeti system I had never touched or needed and had ZERO clue how to do. Kinda what I was getting at with what to do in the transmitter to make the Mercury work......
Next up will be actually setting up some servos and travel, then playing with the gyro. This video was a good help in understanding the set up and gyro functions
Great video
