Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: Power Box Mercury SRS Set Up Help
  1. #31
    Received: 8
    Re: Power Box Mercury SRS Set Up Help
    Quote Originally Posted by Buck Tracker View Post
    Okay update
    Did factory reset, went to set up assistant, following along everything good until assign f-mode switch, it will not recognize my switch which I have assigned as SD under function assignment
    I assume if I can't get it to learn that switch then I have no chance in hell it will learn the gain slider
    Obviously I am doing something wrong with my transmitter as the PB will not learn from it
    I had the same issue Dean....It would recognize the stick movement but when I flipped a switch for the gyro mode control it wouldnít recognize it. I ended up doing my entire mapping manually with the direct technique. Also so far my Mega Turbo Bushmaster is all Iíve setup and it doesnít have any ganged servos on any of the controls....just lots of funky mixes and so forth. So again being a newbie I setup all my subtrims and end points in the transmitter....🤔
    Perhaps Iíll re-do the entire thing...
    Hey have you guys done the latest firm ware updates? I just got the PB IOS blue tooth thingy for that...
  2. #32
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 62
    Given: 149
    Quote Originally Posted by flyloose View Post
    I had the same issue Dean....It would recognize the stick movement but when I flipped a switch for the gyro mode control it wouldn’t recognize it. I ended up doing my entire mapping manually with the direct technique. Also so far my Mega Turbo Bushmaster is all I’ve setup and it doesn’t have any ganged servos on any of the controls....just lots of funky mixes and so forth. So again being a newbie I setup all my subtrims and end points in the transmitter....��
    Perhaps I’ll re-do the entire thing...
    I have not done any updates, maybe I am assuming wrong but mine came fresh from PB to Jeff when I ordered it so kinda thinking it's pretty up to date.
    I bought the USB cable for PC update.
  3. #33
    Dean
    Ponoka
    Received: 62
    Given: 149
    Question
    When I normally set up a servo I increaase the travel from 100 to 125-130 each way to get better resolution, then in the dual rates I set the maximum travel each direction.
    Will I be able to do the same here? Set the travel to 125+- in the transmitter and then set the endpoints in the mercury? This would have the best resolution.
  4. #34
    Dean
    Ponoka
    Received: 62
    Given: 149
    So this video answers some of my questions about servo set up. Seems that he sets up first servo in transmitter as desired then matches second. Didn't cover how to properly set up a single servo or elevator servos properly, but helpful none the less.
  5. #35
    Dean
    Ponoka
    Received: 62
    Given: 149
    Trevor,
    So I've set up the tail section completely with the Mercury and it went well. Leaving wings till last. But I did the throttle in the transmitter should that be okay? edit, reason I did throttle in transmitter was I could not get the throttle to intialize which has to be done before you can adjust end point etc
  6. #36
    Received: 957
    Given: 743
    You won’t have any throttle mixes in the different flight modes so doesn’t matter where you setup center and endpoints. Tx is fine
  7. #37
    Dean
    Ponoka
    Received: 62
    Given: 149
    Rodger that thanks!!
