| Received: 22 Given: 9 |
Finally the engine showed today , of course i'm busy today so I don't have time to play , will get better pictures up later ..![]()
Tease
Here are a couple more, wow is this thing impressive . going to have to get some bigger props , have some 34x12's for my zdz 210 but according to the specs that's way too small . calling for a 34x18 or a 36x12-14 . I do have a 36x14 falcon with pretty fine tips ,that might work .. anyway time to get this beast mounted ..
Sweet!! Love the sealed rockers and welded fittings to the collector ring... 2 things I wish Moki would change to !!
I think I have a couple 34" and 36" props from the Valach210 that you can try if you want.
Thanks Trev may just take you up on that , you know the drill pay $300 for a prop you can't use, buy another and it's still a little off LOL. have a wall of them now . Found a little vid of it running . Just noticed it has 2 exhaust outlets, pretty cool . The ignition wires run into the back of the engine where the coils are mounted,don't know if I like the idea of exposing the coils to all that heat but it will be a very tidy install as the ignition wires are neatly placed beside the intake pipes and run into the back of the block where they are hidden ..
A few shots of the back of the engine and the exhaust ring . the cylinder heads are billet aluminum with Honda valves..
just found this clip . sounds like it hauls .
Here is the engine mounted ,and a couple of shots of the progress .. looks like she will come in around 48LBS
Have the aluminum parts ready for paint. The screws they supply are flat head and way too small . the stearman uses phillips dzus . they also have the screws spaced far too close,so fixed that up ?? trying to find some screws that sit a bit more flush ,they are the correct diameter now but sit a bit proud .
Might as well add some updates of the stearman
There are currently 7 users browsing this thread. (0 members and 7 guests)
