Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 30 Year ,Yellow Aircraft Spitfire build .
    Senior Member Ramjet's Avatar
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    I just purchased my Yellow spitfire back after selling it partly completed 10 years ago . I actually purchase the plane 30 years ago from National Hobby in Toronto started the build but shortly after moved to Parry Sound where it sat for nearly 20 years . One of those planes you really regret selling and was happy to see it go back up for sale in nearly the same unfinished condition . funny when It was sold it was missing the landing gear and I forgot to give him the water slides . well I buy it back for the same price with a Taurus 52 motor and some new yellow landing gear , also came back with a full cockpit kit . I figured why not post surely one of the longest builds ever LOL .First was to repair the damage done by one of the last five owners thankfully they did not get very far with the build,actually just created more work LOL. ..
    I pulled the Taurus as it was a terrible fit and had the carb hanging 2" out one side and would have needed the complete lower cowl cut off on the exhaust side ,again thank God they stopped when they did . As I've had so much luck with my last DLA 56 over the past 6 years I am putting my spare into this one , I know when you remove the L it becomes much less reliable LMAO so I am sticking with DLA ..
    Repaired the glass work to the lower cowl ..
    trial fit the DLA 56.
    hit the milling machine and made a manifold that will fit under the cowl .
ID:	20116   Click image for larger version.
ID:	20117   Click image for larger version.
ID:	20118   Click image for larger version.
ID:	20119   Click image for larger version.
ID:	20121   Click image for larger version.
ID:	20122   Click image for larger version.
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Re: 30 Year ,Yellow Aircraft Spitfire build .
    some pictures of the repaired cowl ..
ID:	20125   Click image for larger version.
ID:	20124   Click image for larger version.
ID:	20126   Click image for larger version.
ID:	20127   Click image for larger version.
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    a few shots of the cockpit work I did 30 years ago
ID:	20130   Click image for larger version.
ID:	20131   Click image for larger version.
ID:	20129   Click image for larger version.
ID:	20132   Click image for larger version.
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    finished up the muffler today ,was a tight fit but all fits nicely under the cowl
ID:	20136   Click image for larger version.
ID:	20135   Click image for larger version.
ID:	20137   Click image for larger version.
ID:	20138   Click image for larger version.
ID:	20140   Click image for larger version.
ID:	20141   Click image for larger version.
    Junior Member sarawnty's Avatar
    Stephen Johnston
    Looks great Roger. Will you have this finished for the spring?
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Sure hope so Steve, I'll give it my best .. If anyone knows of a spinner for a yellow Spit please let me know , the only thing that did not make it home was the spinner .
    Senior Member Vettster's Avatar
    Received: 43
    This is going to be sweet! Glad you decided to share your build here.
    Simcoe Model Aircraft Club (SMAC) Our forum is here.. http://smac.freeforums.net/forum
    http://rccanucks.com/showthread.php?...5596#post15596 clubnomax
    If you do not have the time to do it right, where do you get the time to do it over?
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Been working on smoothing the wing and and finishing the pocket hinges , I replace the balsa trailing edge that is called for and use 1/32 " plywood . looks cleaner with a nice sharp edge and is far more durable . When doing pocket hinges be sure to have the leading edge of the aileron perfectly rounded so you can keep the air gap tight . The hinge joint should be in the center of the round on the leading edge of the aileron ,this will leave a large amount of hinge protruding from the trailing edge of the wing . To better support the hinge you can use Robart removable hinge pockets and insert them in the trailing edge . this will also make your hinges removable in the future ..
ID:	20149   Click image for larger version.
ID:	20150   Click image for larger version.
ID:	20151   Click image for larger version.
    Member
    Lloyd
    Received: 3
    Given: 14
    subscribed Roger. Looking forward to seeing this when finished.
    Lloyd
    May 2016
    Roger S
    DX 18 stealth
    Received: 20
    Given: 9
    Thanks for the encouragement guys . I am no master scale builder so any building tips you may have ,just jump in .. .
