Page 14 of 24 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 231
Thread: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
  1. #131
    Senior Member carrid02's Avatar
    Craig Rideout
    Abilene, Texas
    Futaba, because of Jim
    Received: 36
    Re: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
    Picture flood!
    I got the fuse and MB mocked up and ready for glue! All the CF square tube has been cut and mounted in place. I also decided to use tiny CF rod for the cross pieces because I can pin them into the fuse sides.... and.... I had a ton of the stuff laying around.... so I used it :/
    Fuse glue up should happen sometime today! I need to order main wheels and tail wheels! Ugh, and I need 2 SETS!!! $$$$!!!!
    -Craig
ID:	20337   Click image for larger version.
ID:	20338   Click image for larger version.
ID:	20339   Click image for larger version.
ID:	20340   Click image for larger version.
ID:	20342   Click image for larger version.
ID:	20343   Click image for larger version.
ID:	20344   Click image for larger version.
ID:	20345   Click image for larger version.
ID:	20347   Click image for larger version.
ID:	20348   Click image for larger version.
  2. #132
    Received: 974
    Pinning those tubes into the fuse side is a sweet upgrade man. Great thinking there!!!
    Always stuff to learn by reading this stuff
  3. #133
    Craig Rideout
    Abilene, Texas
    Received: 36
    Thanks Trev! I had to be slightly different. lol
  4. #134
    Craig Rideout
    Abilene, Texas
    Received: 36
    SWEET!... the glue is drying on the fuse! Once this dries, Iíll add the CF framework to the bottom, finish up the tail/tailwheel support and get this fuse off the work bench!
    -Craig
ID:	20357   Click image for larger version.
ID:	20358   Click image for larger version.
ID:	20359   Click image for larger version.
ID:	20360   Click image for larger version.
  5. #135
    Senior Member Skier1960's Avatar
    Jun 2017
    Robert
    Alexandria Ont
    Received: 18
    Given: 45
    Quote Originally Posted by carrid02 View Post
    SWEET!... the glue is drying on the fuse! Once this dries, I’ll add the CF framework to the bottom, finish up the tail/tailwheel support and get this fuse off the work bench!
    -Craig
    It looks like your using epoxy on some of the CF and Hysol on others? If so what would be the purpose? Great job BTW
  6. #136
    Senior Member NDW's Avatar
    Dave Woon
    Out in a corn field looking for my plane
    Spectrum DX18 / Futaba 10J
    Received: 118
    Given: 6
    Looking great Craig. Just one question. I see you used hysol in the front of the plane but what glue are you using for the carbon pieces in the rear. Looks cloudy / clear. Another hysol formula. Looks kinda like 3M glue?
    D.
    Confucius says: Going to McDonald's for a salad is like going to a Hooker for a hug...:smug
  7. #137
    Craig Rideout
    Abilene, Texas
    Received: 36
    Good catch!... you guys are paying closer attention than I thought!
    I used Hysol 9462 on the lugs because I wanted a little thicker fillet between the square CF and the rod. I really wanted that glue to stay where I put it.
    The rest of the carbon fiber was done with Hysol Eons because it’s a little thinner and I wanted it to fill in nicely around the square/rod (by itself). I probably could have used 9462 but I would have had to work the glue into the corners a little more.
    -Craig
  8. #138
    Craig Rideout
    Abilene, Texas
    Received: 36
    Big ole fantastic morning in the shop!
    I got the tailwheel and battery hatch support done! I also got all the bottom fuse support and cross pieces installed!
    Just a few more CF pieces to install before I pop the fuse off the building board! Then I start ALL OVER on the 109
    -Craig
ID:	20380   Click image for larger version.
ID:	20381   Click image for larger version.
ID:	20382   Click image for larger version.
ID:	20383   Click image for larger version.
  9. #139
    Received: 974
    Saaaaaweeeeeeest!!!!
  10. #140
    Craig Rideout
    Abilene, Texas
    Received: 36
    Hooooly fuselaaaaage batman!!!!
ID:	20407   Click image for larger version.
ID:	20408   Click image for larger version.
ID:	20409   Click image for larger version.
