Page 21 of 21 FirstFirst ... 11192021
Results 201 to 204 of 204
Thread: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
  1. #201
    Received: 968
    Re: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
    Looks awesome Craig!!!!
  2. #202
    Senior Member carrid02's Avatar
    Craig Rideout
    Abilene, Texas
    Futaba, because of Jim
    Received: 36
    Thanks Trev!!!
    Started foam work! Glued the lower deck together and started taping/glueing sheeting. Trying to get lower deck, upper rear deck and rudder/fin done!!!
    -Craig
ID:	23101   Click image for larger version.
  3. #203
    Craig Rideout
    Abilene, Texas
    Received: 36
    For glueing, hereís the technique I use:
    1. Tape all the sheets together. Make seams tight!!!
    2. Open up the seam and apply small bead of glue. (I used Titebond II)
    3. Slide sheet back to close the glue gap.
    4. Scrape excess glue with a dull/semi blunt metal or plastic scraper.
    5. Lightly sand across the gap with 120 sandpaper and tape the entire seam.
    6. Repeat 2 through 6 until entire skin is glue and taped.
    7. Add some handy dandy angle weights that everyone wants )))
    -Craig
ID:	23103   Click image for larger version.
ID:	23104   Click image for larger version.
ID:	23105   Click image for larger version.
  4. #204
    Craig Rideout
    Abilene, Texas
    Received: 36
    Ok, I got the sheeting glued together for the rudder/fin, the top rear deck, the lower deck and the hatch. Now Iíll sand them all and get them attached to foam!
    For sanding, Iíll do 120, 220, 320, 400, hairspray, then 600. This has been a proven method so Iím sticking to what works!
    -Craig
ID:	23115   Click image for larger version.
ID:	23116   Click image for larger version.
