Page 20 of 24 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 231
Thread: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
  1. #191
    Senior Member carrid02's Avatar
    Craig Rideout
    Abilene, Texas
    Futaba, because of Jim
    Received: 36
    Re: Carden 124 Pro and 109 "Mini Pro" -Carbon Edition-
    Before cutting off the stab phenolic, I slid the stabs on to see how they fit to the fuselage side. Fit was perfect!!!
ID:	21275   Click image for larger version.
  2. #192
    Craig Rideout
    Abilene, Texas
    Received: 36
    I also got the wingtube located and glued in with a fillet of epoxy. Ill cut the ends off once the epoxy dries.
ID:	21277   Click image for larger version.
ID:	21278   Click image for larger version.
ID:	21279   Click image for larger version.
  3. #193
    Craig Rideout
    Abilene, Texas
    Received: 36
    Not much, but its progress!
    I wanted to show off the CF trammel tool I have. I use it to make sure my branch lines are exactly 90 degrees to the straight line. Then, after everything is locked up (and with the tubes centered), I use the points to make sure everything is good to go.
    These pics are me checking the branch lines.
    -Craig
ID:	21450   Click image for larger version.
ID:	21451   Click image for larger version.
ID:	21452   Click image for larger version.
  4. #194
    Craig Rideout
    Abilene, Texas
    Received: 36
    Here a shot of how I double check the tube placement. Now waiting for glue to dry so I can cut off the wingtubes.
    -Craig
ID:	21454   Click image for larger version.
ID:	21455   Click image for larger version.
ID:	21456   Click image for larger version.
ID:	21457   Click image for larger version.
  5. #195
    Senior Member Carlisler's Avatar
    Scott B
    Received: 298
    Given: 436
    Still cant get over how great that carbon looks in that fuse!!
    Great Job man!
  6. #196
    Craig Rideout
    Abilene, Texas
    Received: 36
    Thanks Scott. I really like how they’ve turned out so far. More to come.
    -Craig
  7. #197
    Craig Rideout
    Abilene, Texas
    Received: 36
    Well, I think its time for an update. IMAC season is over so Im planning to hit these planes hard over the build season and see what happens!
    I started by adding the 1/2 x 1/2 balsa around the top of the motorbox on both planes.
    Next, I added balsa sheeting in the space between the motorbox wings and the fuse sides.
    Last job for now was cutting out the carbon pieces for the top. Those will get epoxied in asap!
    Ive got a few more small jobs to get the fuse boxes done, then Ill start prep work for lower deck, rear deck and vert fin.
    -Craig
ID:	23047   Click image for larger version.
ID:	23048   Click image for larger version.
ID:	23049   Click image for larger version.
ID:	23050   Click image for larger version.
  8. #198
    Craig Rideout
    Abilene, Texas
    Received: 36
    Aaaand heres some carbon fiber goodies.
    -Craig
ID:	23052   Click image for larger version.
ID:	23053   Click image for larger version.
  9. #199
    Senior Member Skier1960's Avatar
    Jun 2017
    Robert
    Alexandria Ont
    Received: 18
    Given: 46
    Quote Originally Posted by carrid02 View Post
    -Craig
    Real cool stuff... For me building season is from November to April and from April to October is repair season!!
  10. #200
    Craig Rideout
    Abilene, Texas
    Received: 36
    Ha, I hear you Robert. Everyone definitely needs a repair season!
    Thought Id show these... I use 1/2 rocket tubes from Estes for servo tubes. Theyre small/light... these are model number BT-5.
    I got those installed and all the remaining carbon pieces. Sheeting/sanding on rear decks has begun so Ill update as I move along with those pieces.
    -Craig
ID:	23079   Click image for larger version.
ID:	23080   Click image for larger version.
