Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Refueling problem solved!
    Senior Member JBajkor's Avatar
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Re: Refueling problem solved!
    Quote Originally Posted by itizme View Post
    In description ot states not for gas
    It is a brass gear pump OK to use with diesel, so I don't see a problem using gas.
    MAAC 12443
    Miracles are like magic. You will never see them if you don't believe.
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Quote Originally Posted by JBajkor View Post
    sure, now you tell me this.
    Just have to ask Joe
    I was using that setup at Forest jets. I also have a Secraft pump setup as well, but they are kind of pricey. Never had much luck with the Sullivan pumps either.
    You can buy just the pumps from ready-to-use setups. They are made by Greylor and will ship direct to you.
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Refueled 4 times at the fun fly today and the pump is great. It is barely working and fills up the larger tank in 1/4 time as compared to Sullivan.
    Senior Member RC_MAN's Avatar
    Aug 2015
    Peter Doupnik
    Windsor Ontario
    Futaba 18 MZ, Powerbox Core,
    Joe you may want to ensure that you ground the fuel pump. At the high flow rates you may be introducing static electricity into your fuel system.
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Thanks Peter, I understand your concern. However, what would I ground? Fuel lines, UAT, tank, everything the fuel comes in contact with is non-conductive.
    Nov 2015
    Len Steg
    Will the pump defuel also (reverse fuel to empty tanks) ?
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    It is a simple brushed motor so should run in reverse. However, I only have an ON/OFF switch installed.
    If it's really important for you, I will try connect reverse battery and report back.
    Nov 2015
    Len Steg
    If it is a geared pump it should work....I have a jersey pump that seems to be doing the job just great.
    Made up my own system using a few jersey parts stuff that was on sale and saved quite a bit of money.
    Received: 21
    The only difference is how well isolated& sealed the brushed motor is from any potential gas leak into the motor .. the gear pump it's self would be fine but what if gas fumes get to the brushes , car pumps are submerged in fuel so the mix is to rich to light .. just a thought ..
