Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Refueling problem solved!
    Senior Member JBajkor's Avatar
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Last year, I had a Sullivan pump that lasted one season then the motor burned up. Got a new one and the third day at the airfield, I noticed smoke coming out of the hole for the switch. That's not going to last. So I searched for an appropriate replacement.
    MAAC 12443
    Miracles are like magic. You will never see them if you don't believe.
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Re: Refueling problem solved!
    Got one of these cheap fuel pumps made for Toyota from China. If it can pump fuel from a 40 liter tank, should be fine. I soldered smaller fittings to match my fuel line. It all looked fine on paper but, when I got to the airfield it was way too slow. Running on 3S lipo, it took 1/2 hr getting 3/4 full before I gave up and refit the Sullivan. I tried 4S but got little if any improvement.
    Even my backup hand pump is faster!
ID:	18960   Click image for larger version.
ID:	18961   Click image for larger version.
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    I searched everywhere for an answer. Do not want to spend close to $300 for a fancy hobby pump.
    Look what I found.
ID:	18963   Click image for larger version.
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    This was $79 + shipping from amazon.ca
    Rated for 12V and more volume than I need, so I tried it with 2S Lipo. Got fuel lines all connected and a switch installed. I ran a test to fill a 1 liter container. Took 16 seconds! At that rate, it will fill my plane in just about one minute! Looking forward to using it at a fun fly this Saturday. Here is a picture to show size comparison.
    Junior Member Heligaz's Avatar
    Gaz
    Toronto
    Hi Joe
    Would you please put a link to pump. Not sure what to even search for
    Gaz
    Toronto
    I found it
    Here's a link
    https://www.amazon.ca/Amarine-Made-S...uel+pump&psc=1
    Joe, are you using this for gas?
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    I am using it for jet fuel. (kerosene) Should work fine for gas.
    One thing I should mention: The fittings that come with it are for 1/2" hose. I found replacements for 3/16 hose at Low's.
    Senior Member itizme's Avatar
    Steve W
    Angus
    Futaba MZ, Futaba SZ
    Received: 210
    Given: 73
    In description ot states not for gas
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Or you can buy a proper pump made for the fueling job in Canada.
    Bought one of these from Icare at the Toledo show. You can buy one with or without a battery supply attached. Nice little unit that pumps pretty well on 2s battery.
    http://www.icare-icarus.com/Electric...mp_p_1335.html
    Dec 2015
    Joe Bajkor
    Hamilton, Ont
    Quote Originally Posted by pylonboy View Post
    sure, now you tell me this.
