Results 1 to 9 of 9
Thread: Testing failsafe
    Orval Altwasser
    YellowGrass, Sasatchewan
    Spektrum , FlySky i10
    Received: 17
    Red face Testing failsafe
    Spent some time this afternoon setting up failsafe on the 1/3 scale Super Cub. My failsafe commands are as follows: Throttle- back to low idle,elevator - slight up, flaps down 15%, rudder and ailerons both back to neutral position. Am I on the right track here guys or what do you suggest. Then also, how do I test the system on the ground. Everything Ive read says to power off the transmitter . Only problem is my FlySky fsi10 will not power down unless the rx is powered down first. Suggestions are welcome. Joe T , this means you!
    Received: 76
    Re: Testing failsafe
    Um er... I don't have a flysky so I would not know. But top of mind would be to pull the TX battery to test the failsafe.
    Orval Altwasser
    Received: 17
    Wont that kill my memory and loose all my settings on two stored Models?
    Received: 76
    Quote Originally Posted by Lowrider27 View Post
    No it will not. There is NV ram inside all modern TX's, models are stored in there. The main battery is for the TX not for model memory.
    Orval Altwasser
    Received: 17
    Oh. Ok great! I'm gonna try pulling the battery then . Thanks Joe. See--- I knew you would know!
    Senior Member R Plante's Avatar
    Randy P
    futaba
    Received: 27
    Given: 24
    Personally I set my failsafe to engine off full left aileron full left rudder down elevator.... my reasoning is of I'm flying in the safe area a d lose control it will spin in in a safe area... the hold last or similar while waiting to regain control gives the plane time to get on an area where there might be people or property .... just my opinion but I would rather lose a plane than risk injuring someone or damaging property
    Orval Altwasser
    Received: 17
    Very good reasoning Joe. My situation is a little different. I fly 99 % of the time by myself on my farm land. No people around me when Im flying . Closest neighbor is 2 miles away.
    Orval Altwasser
    Received: 17
    Sorry Randy. I didn't check who was replying before I replied . Should read-- Good reasoning Randy!
    Senior Member -Rick-'s Avatar
    Chesley Ontario
    Horus
    Received: 35
    Given: 59
    Quote Originally Posted by R Plante View Post
    I do the same, for the same reasons.
