Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Atomizing Smoke Oil Injection Nozzles, header no-weld kits, & turbine smoke tubes
    Junior Member crankcase's Avatar
    Oct 2017
    Harlan R
    Isanti, MN
    Shipping : I will ship at buyers expense.
    Quantity: Multiple
    Accepted forms of payment : Paypal
    My Location: MN USA
    Model Number: Smoke Nozzle
    New or Used: Item is new, unused
    Trades: No trades.
    Manufacture: BDSmokes
    Asking Price: $20
    Atomizing nozzles produce a fine fan shaped mist of oil for smoke system applications. Produces a fine mist at both low volume and slow pump speeds, but also capable of flowing over 8 oz / min. More than DOUBLE your smoke time per tank versus the traditional crimped tubing nozzles, complete burn, and less mess. Adjustable positioning for ease of installation and maximum smoke. Nozzles are precision machined from one solid piece in either stainless steel or grade 2 titanium and use 10-32 thread patterns.
    Nozzle kits: Include 1 nozzle, locknut, safety wire, logo sticker and installation instructions. $20 USD ea.
    No-weld kits: A bolt on solution for adding smoke nozzles to headers for canister exhaust systems. All SST construction. No-weld kits include all components for installing one nozzle to one header tube: contoured nut, contoured spacer, lock washer, nut & installation instructions. $8 USD per kit. Nozzle not included.
    No-weld kits are offered for the following header pipe sizes determined by your header OD size:
    20mm
    22mm
    1" or 24mm-28mm
    28mm
    Atomizing turbine smoke tubes: Turbine smoke tubes produce a flat fan ultra fine mist for jet turbine applications. Smoke tubes available 3/16" diameter in 10", 12", or 14" lengths with standard or optional high output orifice sizes depending on turbine application. Features one piece TIG welded full Stainless Steel construction, Flared end for better tubing retention, Kink free tube bending system, and universal mounting clips., safety wire for smoke line connection security, logo sticker & instructions. $37.50 USD ea.
    Standard USPS First class shipping with tracking is $5.00 per order to CONUS US, USPS package International shipping to Canada is $11 per order, Worldwide USPS package International is $16 per order.
    Regular PayPal only please.
    https://youtu.be/C3o7N5MTq-k
ID:	17483   Click image for larger version.
ID:	17484   Click image for larger version.
    Oct 2017
    Harlan R
    Isanti, MN
    Re: Atomizing Smoke Oil Injection Nozzles, header no-weld kits, & turbine smoke tubes
    PM sent to Heligaz
    Oct 2017
    Harlan R
    Isanti, MN
    A few nozzle location installation pics and some detailed nozzle spray pattern pics.
ID:	18493   Click image for larger version.
ID:	18494   Click image for larger version.
ID:	18497   Click image for larger version.
ID:	18495   Click image for larger version.
Name:	da120 nozzle location.jpg
    Oct 2017
    Harlan R
    Isanti, MN
    One more pic of nozzle installation instructions and kit components for suitcase, Pitts, and OE style mufflers.
    Senior Member -Rick-'s Avatar
    Chesley Ontario
    Horus
    Received: 38
    Given: 63
    Crankcase, new smoker here!
    I am going to use your nozzles just not sure where to put it. Should I put it in the exhaust flange or should it go into the pipe? The pipe would be tight as there is no straight run and the only place I can see is where the blue arrow points to. The red X is where I would put it in the flange pointing down stream. Which would be better?
    Also what size tank should I use for a 60cc plane? For lets say 5 minutes of smoke?
    Thanks,
    Oct 2017
    Harlan R
    Isanti, MN
    Hey Rick, the red "X" on the flange is too close to the cylinder. Ideally we want to be about 1" to 1.5" down from the flange. In that area you have the option of pointing upstream or downstream. If your pointing upstream, test your pump with water with the header removed when your setting up the nozzle depth. Meaning that there is fine adjustment as the entire nozzle can be threaded further into the muffler or back it out for some fine tuning of where the spray lands. What we don't want to do is get a full spray up and out of the muffler at the flange if your directing upstream. That would be spraying right into the cylinder when installed and that's no good. A little misting out the muffler flange is ok, just not full force spray.
    I don't see your invoice off hand so I'm not sure if you snagged your nozzle from a buddy, and have a no weld kit available for your nozzle. but for installation on the header the no-weld kit is an option that works great. For the secondary location, the blue dot area in question. Were you planning on brazing a nut and installing? Otherwise a no weld kit just a little upstream of the braze seam is good too.
    Smoke time per tank can vary so it depends on your flying style and or throttle management. Estimate 3oz to 4oz per minute at WOT. I would start with a 16oz for starters. I have one guy getting 14-16 min from twin nozzles on a 170cc. Smoke comes on at takeoff and stays on till it's run out. So 2.5oz to 2.8oz per nozzle and it is dense Smoke!
    Here's a no weld installed on a 1" header. GP61.
    Oct 2017
    Harlan R
    Isanti, MN
    More no-weld kit details:
    The no weld kit consists of all stainless steel components. Several sizes available and I can build dies upon request in about 2 weeks. Right now we have the following sizes as measured by your header OD pipe size. 14mm, 20mm, 20mm Keleo ring, 22mm, 24mm-28mm.
    The contoured nut is placed on the outside of the header pipe to find a spot where the curvature closely matches. It works on straight or curved sections. (When installed the contoured nut is on the inside of the header)
    Once you find the spot, mark the location with a thin marker and drill a hole.
    Insert the contoured nut, or fish it in place using a string.
    Grab the nut with your fingernail and then install the contoured spacer with the curved side against the header pipe. Then the lockwasher and nut. If you use a scrap of yellow gas line and temporarily install it on the nozzle & mark it with a marker you can keep track of the spray direction.
    No-weld kits work with headers of varous thickness. Anywhere from zero wall thickness up to over 1mm wall thickness.
ID:	18988   Click image for larger version.
ID:	18989   Click image for larger version.
ID:	18990   Click image for larger version.
ID:	18991   Click image for larger version.
    Chesley Ontario
    Horus
    Received: 38
    Given: 63
    No I do not have the nozzle yet, I was not to sure what I needed to do this so I asked. I can do the no weld kit, it looks like the way to go. And I will put it into the curved part of the header. I first have to take the cowl off again to measure the OD of my header.
    I will place an order shortly with you. I will get back to you via a PM.
    Thanks!
    Oct 2017
    Harlan R
    Isanti, MN
    No problem. Just let me know.
    I should also make an update to the ad to let everyone know that I now offer some additional smoke accessories.
    Sullivan S756 check valve $10ea
    Nickle plated brass tee fitting $4ea
    Nickle plated brass line coupler $3ea
    All fittings come with safety wire to secure your tubing connections. Flat rate shipping.
    $5 US domestic
    $11 Canada
    $16 International
ID:	18993   Click image for larger version.
ID:	18994   Click image for larger version.
ID:	18995   Click image for larger version.
    Chesley Ontario
    Horus
    Received: 38
    Given: 63
    PM sent.
