Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
Thread: Quad'itizing a 43% Carden
    Received: 764
    Given: 676
    This 43% Carden Hamilton Watch 260 started life with an MVVS-190 quad on pipes.
    Really liked it but decided to experiment with it lighter using a GP176evo on the same pipes. Definitely a lighter feel but I just keep getting pulled back to the quads!
    Recently ran about 40 flights on my new DLE222-V3 quad in my 41% CARF Suhkoi and have been so impressed! So smooth and crazy power! Hauls around that huge 48lb Suhk like a foamy!
    Decided to retrofit the Carden for the DLE222. Will also put it on the Planebender smooth pipes! I expect some nutty performance at 42lbs!!
    Here was the build thread on the Carden....
    http://www.rccanada.ca/rccforum/showthread.php?t=207378
    Received: 764
    Given: 676
    Re: Quad'itizing a 43% Carden
    Video of how it started... with MVVS190...
    Then with the GP176evo on smooth pipes....
    Received: 764
    Given: 676
    I built this Carden for the MVVS190 which is a really short quad like the Mintor220. For the GP176evo, I used a plywood donut for a standoff.
    But the DLE222 is long like the DA200 and ZDZ224... means lobbing off the motorbox.
    (Don't worry... all sides of the motorbox will be strengthened soon)
    Received: 764
    Given: 676
    Got the new firewall Hysol'd in place. Will clean it all up once cured.
    Over the next few days I will stiffen the motorbox and tie in this new firewall
    Senior Member Bhughes's Avatar
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 346
    Given: 294
    Love this plane
    TROUT FARM FLYERS
    Down with gyros
    #alumacraft
    Received: 764
    Given: 676
    New motorbox is nearly complete. Just have the gusset the firewall.
ID:	16642   Click image for larger version.
ID:	16643   Click image for larger version.
    Received: 764
    Given: 676
    Bolted the motor on. Fits perfectly.
    Will work on exhaust and baffling over the next few days!
ID:	16645   Click image for larger version.
ID:	16646   Click image for larger version.
ID:	16647   Click image for larger version.
ID:	16648   Click image for larger version.
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 427
    Given: 446
    Making me miss it already
    Received: 764
    Given: 676
    On all of the past quads, I have done a fairly elaborate baffling system. However the cooling is actually too much sometimes, especially if it gets cool out (has trouble getting up to temp).
    On the CARF Suhkoi I opened up the baffling a ton from normal and was really impressed with the temp profiles over all the flights whether 10deg or 35deg ambient.
    For this one I am going to try a more standard baffling setup one would see on a twin (closer to the Suhkoi setup). I will watch my temp sensors closely and see how this works.
ID:	16651   Click image for larger version.
ID:	16652   Click image for larger version.
    Received: 764
    Given: 676
    These headers are from DLE Australia. Except for a little thinner flange they are just like MTW headers for DA. Very impressed.
    They come about 17" long. Looking at all the past quad testing on pipes I went with 12" headers. I'm not too worried since the pipes are Planebender Smoothpipes and testing has shown they are not peaky and sensitive to headerlength like MTW and KS.
ID:	16654   Click image for larger version.
ID:	16655   Click image for larger version.
