Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: ZN-Line Wizard XXL / Behotec220
    Received: 923
    Given: 737
    Re: ZN-Line Wizard XXL / Behotec220
    The construction of the wings is beautiful... 0 complaints. Love that Electron gear. Very nice machining, smooth operation, amazing brakes. Used a 4-plug TBolt connector - aileron, flap, retracts, brakes
    Negatives.. disappointing with the cost and precision of this kit that there is 0 details on servo arm length and linkage length. Also, no hardware supplied. Lastly, even though the gear was installed, there were no flat spots on the pins and no lock-tite used. Had to pull the gear and rebuild.
    Minor stuff but I expect better from such a high end and expensive kit.
ID:	16392   Click image for larger version.
ID:	16393   Click image for larger version.
    Received: 923
    Given: 737
    Hopefully these dimensions save someone time in the future!!!
    Ailerons
    19mm - servo arm length
    63mm - linkage length
    Flaps
    25mm - servo arm length
    103mm - linkage length
    Received: 923
    Given: 737
    Elevator servos installed and linkages complete.
    I needed to make up a 1/4" plywood frame to raise the servos on the stock rib so that the servo arms lined up with the cutout in the skin.
    16mm - servo arm length
    98mm - linkage length
ID:	16395   Click image for larger version.
ID:	16396   Click image for larger version.
ID:	16397   Click image for larger version.
ID:	16398   Click image for larger version.
    Received: 923
    Given: 737
    Here is the paint scheme however we are not sure on the colours yet... likely different than the colours in the attachment.
    Senior Member Daren71's Avatar
    Apr 2015
    Daren
    Mississauga, ON
    Received: 19
    Given: 147
    Looks good Trevor. Where are the flaps? Those look like huge ailerons for a jet.
    Daren
    Received: 923
    Given: 737
    Ya Daren... massive ailerons!! If you look close in the pics, about 40% of it is flap and 60% aileron!!
    Apr 2015
    Daren
    Mississauga, ON
    Received: 19
    Given: 147
    Oh OK, I went back and looked at the wheel well pics on page one. That's kinda neat. Big wheel well!!
    Thanks Trevor.
    Daren
    Received: 923
    Given: 737
    JB220, pipe and all wiring of the tail is complete! Got servos working!!
ID:	17048   Click image for larger version.
ID:	17049   Click image for larger version.
    Received: 923
    Given: 737
    Inside.
    Tonight I will start working forward... fuel system, finish wiring and equipment layout!
ID:	17051   Click image for larger version.
ID:	17052   Click image for larger version.
    Received: 923
    Given: 737
    The interior is complete.
    Radio programming, weight check and initial CG check tonight! Will redo weight and CG after Peter paints it.
ID:	17059   Click image for larger version.
ID:	17060   Click image for larger version.
ID:	17061   Click image for larger version.
