Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: H9 PA-18 Super Cub - Scheme Change and Assembly
  1. #21
    jeweler
    Guest
    Re: H9 PA-18 Super Cub - Scheme Change and Assembly
    Quote Originally Posted by Carlisler View Post
    Painting has come to a bit of a stop due to facilities..... arrgghh!
    So I have had the chance to do some more covering, and the rudder is covered, and the fin has 1 side covered for now.
    There are some really interesting curves in this covering and the new beacon light mount!
    Ya the beacon mount sticks out like a.........well a beacon mount.
    Looking great!
  2. #22
    Senior Member Carlisler's Avatar
    Scott B
    Received: 305
    Given: 439
    Quote Originally Posted by jeweler View Post
    Thanks guys,
    But, Oh boy, was there ever some cursing during that process.....
    All good tho! Access to the fuse for the assembly is priceless!!
    Waiting to get some paint booth time locally, and make the paint part go away.... argghhh!
  3. #23
    Junior Member Nut-Ten's Avatar
    Larry Pierce
    Wasaga Beach
    Spectrum 10-T
    Given: 7
    Hello There :
    This is the Cub that Bill mentioned, T'was mine.
    Larry
  4. #24
    Scott B
    Received: 305
    Given: 439
    I am back into this one this evening!!! Yahooo!!
    But starting with the paint again...... aaarrrgggghhhhhhh
  5. #25
    Scott B
    Received: 305
    Given: 439
    This Cub is back on the build table and covering has recommenced! Oh the smell of fresh Monokote! LOL
    Also, got into the set up of servos, as it is a pure joy to work on the plane with the covering off, compared to the covered ARF!
    in the process I spent the night playing with the AR9020 that would not fire up as usual.. not sure why, as it was bound before. but created these weird aircraft files in my transmitter, which I cannot access.
    I tried 4 different batt's, of 3 different types, and nothing more than a blip of the light and twitch of one servo. arrggh!
    so I tried 3 other Rx's with the same setup's and all were good. I went back to the AR9020 and it worked fine...... WTF! will monitor this...
    Tonight I should finish most of the wiring on the secondary floor, and be ready for the interior to be installed after paint is done.
  6. #26
    Received: 986
    Excited to see this come together Scott!!!
  7. #27
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    Quote Originally Posted by carlisler View Post
    this cub is back on the build table and covering has recommenced! Oh the smell of fresh monokote! Lol
    also, got into the set up of servos, as it is a pure joy to work on the plane with the covering off, compared to the covered arf!
    In the process i spent the night playing with the ar9020 that would not fire up as usual.. Not sure why, as it was bound before. But created these weird aircraft files in my transmitter, which i cannot access.
    I tried 4 different batt's, of 3 different types, and nothing more than a blip of the light and twitch of one servo. Arrggh!
    So i tried 3 other rx's with the same setup's and all were good. I went back to the ar9020 and it worked fine...... Wtf! Will monitor this...
    Tonight i should finish most of the wiring on the secondary floor, and be ready for the interior to be installed after paint is done.
    foo tab bah !!!!!
  8. #28
    Scott B
    Received: 305
    Given: 439
    Quote Originally Posted by Machzx View Post
    foo tab bah !!!!!
    FOO in French means crazy....
    TAB means the comparatively heavy credit (or other) required to get one...
    BAH, I can't be bothered changing the entire fleet over....
    LOL!!
  9. #29
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    i hear that
    at night i drink beer and stare at the all knowing blue eye pray that someday i will have time to learn how to program mixes
  10. #30
    Scott B
    Received: 305
    Given: 439
    OK, it has been a busy week (and weekend past) but I have been playing with the cub a bit, and getting some things worked out.
    For fun, I test fit the floor plate, seats, and a control stick. All good there.
    I also installed most of the servos, with only some minor securing of wires left. There will definitely be limited access to these once covering is complete!! The bottom should be covered tomorrow.
    I am prepping for a paint run, so I wanted to ensure the cowl is cut and ready for primer. I installed the Valley View 40 twin and marked the exhaust holes on the cowl. I will cut tmrw when everyone is gone. This engine is tiny, I can't wait to see and hear her run!
    Although, the mufflers do qualify as 'exhaust diverters'!! LOL
ID:	2804   Click image for larger version.
ID:	2805   Click image for larger version.
ID:	2806   Click image for larger version.
ID:	2807   Click image for larger version.
ID:	2809   Click image for larger version.
ID:	2810   Click image for larger version.
