Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: H9 PA-18 Super Cub - Scheme Change and Assembly
    Senior Member Carlisler's Avatar
    Scott B
    Received: 305
    Given: 439
    Re: H9 PA-18 Super Cub - Scheme Change and Assembly
    I can't tell you how nice it is to be able to assemble this plane with the fuse uncovered!!
    Getting access to all the required tight areas would be a much different scenario if the Monokote was still on!
    So while priming, painting and clearing is going on in the garage, I got the ignition temporarily installed in the fuse nose, and a cut through-hole for the leads to the cowl.
    I added some Velcro to the bottom of the ply plate because access later will be difficult and I hate losing the battery straps, and Rx straps by falling out of their place!
ID:	773   Click image for larger version.
ID:	774   Click image for larger version.
ID:	775   Click image for larger version.
    Received: 986
    Ya - very handy!!! Nice work on the progress. Still shocked at how many parts needed painting!!
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    the nice thing is it wont be cookie cutter same as the rest
    im waiting for a giant scale cub to catch my eye
    Senior Member williame3590's Avatar
    Bill Allemang
    Caledonia, Ontario
    Received: 66
    Given: 99
    I know where there is a beauty Ed.....5,000.00 though! 1/3 scale, extremely well done.
    Bill
    Scott B
    Received: 305
    Given: 439
    Yikes! Big price, but any pics??!! would be nice to see!!
    Scott B
    Received: 305
    Given: 439
    Well, I have been working on the prime, paint , and clear, part of the project, and the garage is a mess! LOL
    Parts hanging or laid out everywhere and in different stages of paint.
    The paint match from Cawthra Automotive is awesome! too bad I go thru so much! So tonight I went to Rona and they matched a quart pretty darn nicely!!!
    See the code for reference if you need some. (FYI the CARQUEST code for Cub Yellow in their system is 6177A)
    With a few coats all parts will match up great, but the ailerons will need some TLC in the application due to the recesses in the surface.
ID:	832   Click image for larger version.
ID:	833   Click image for larger version.
ID:	834   Click image for larger version.
    Scott B
    Received: 305
    Given: 439
    I also started on the fab of the scale beacon light for the top of the rudder.
    I am still looking for a better lens cover, but this is it for now. Any thoughts or ideas of where to get something that would look like the pics of the real thing?
    The size of the mount is about 5/8" to 3/4". Any help would be appreciated!
ID:	836   Click image for larger version.
ID:	837   Click image for larger version.
    Scott B
    Received: 305
    Given: 439
    When things are drying, I have been taking advantage of the covering being off the plane and setting up what I can prior to fuse covering!
    Most items are planned for space, and some placed. I need to get some 2 servo T-Bolt connectors from Jeff, and a pretty prop.
    Those servos and Ibec will be behind the interior kit hat rack, and will be hidden when done.
ID:	839   Click image for larger version.
    Scott B
    Received: 305
    Given: 439
    Painting has come to a bit of a stop due to facilities..... arrgghh!
    So I have had the chance to do some more covering, and the rudder is covered, and the fin has 1 side covered for now.
    There are some really interesting curves in this covering and the new beacon light mount!
ID:	1055   Click image for larger version.
ID:	1056   Click image for larger version.
    Senior Member NDW's Avatar
    Dave Woon
    Out in a corn field looking for my plane
    Spectrum DX18 / Futaba 10J
    Received: 119
    Given: 6
    Look'n good Scott......
    D.
    Confucius says: Going to McDonald's for a salad is like going to a Hooker for a hug...:smug
