Received: 0 Given: 0 |
Received: 43 Given: 32 |
Your going to have to wait till Christmas to find out lol![]()
Simcoe Model Aircraft Club (SMAC) Our forum is here.. http://smac.freeforums.net/forum
http://rccanucks.com/showthread.php?...5596#post15596 clubnomax
If you do not have the time to do it right, where do you get the time to do it over?
Finally home long enough to open the mold... I have a fuselage!!Very happy with the results.
Weight so far...
2 wings...1273
2 Horizontal stabs..654
Fuse..2155
Total...4082 grams or 9 lbs
Still have to include the vertical stab,wing tips and ailerons..so possibly under 12 lbs. Much lighter than I expected. I was figuring about 15 lbs. The wings will be made much lighter in the future as I have redesigned my method for holding the wings on.
Received: 20 Given: 9 |
Great job Trevor , best building I've seen since living by Graeme Mears and hanging out in his workshop years ago .
Hey thanks for the huge compliment Roger!!![]()
Noticed a couple of problems. One not so big..but the other will take a bit of time.
A closer look at the fuse shows a slight misalignment. Good enough for the prototype but not production. That has been fixed with the addition of some 3/4" frames to stop the top mold from twisting. The other is more complicated. I chose the wrong location for the elevator tube and this means re working the molds. Not the end of the world..but a set back for sure. The tube needs to be further forward to place the load over the vertical former for structural strength. Oh Well.. no one said it was easy![]()
I glued the lower halfs together. I'm impressed with how light it is but yet super strong.
Yeah that honeycomb is great for panel stability and super light , I see your using carbon fiber in the more critical areas to prevent fractures ,good job ..
Cheers Roger
Got a lot done today. Modified the molds for the new spar location, layed up a new rudder with the honey comb material, laid up a canopy and most difficult of all figured out the formers for the spar. The electric version is easy with a solid tube receiver and tube going right across the engine pod, but the turbine version is cut into 2 pieces to allow for the pipe to pass. I will be using the turbine version for proof of concept.
Things to do...
Make hatch
Finish engine pod formers/engine mount
Relocate spar location in Horizontal stabs.
Glue on wing tips.
Are you ready for this....
ASSEMBLE PLANE!!![]()
Received: 0 Given: 2 |
Merry Christmas Trevor
