Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: SM 1/5 F-9F Cougar
  1. #21
    Received: 3
    Re: SM 1/5 F-9F Cougar
    Great info Jan, thank you. If you have any pics you'd care to share that would be much appreciated. I went ahead and bought the BVM supplementary manual and I must say, best $45 I've spent in a while.
  2. #22
    Received: 3
    Any way been back to working on this project...stabs are done with MKS 747ís for the tight fit
  3. #23
    Received: 3
    Rudder is done...had some looseness with the piano wire so I fabíd up a wooden bushing. Much more snug now..had to make a horn as nothing was supplied...I tried to eliminate all slop but Iím still fighting with it a bit. Decided to move on and maybe revisit that later
ID:	17195   Click image for larger version.
ID:	17196   Click image for larger version.
  4. #24
    Received: 3
    Hereís a vid of the rudder
    https://youtu.be/2XEsBbtg1V0
  5. #25
    Received: 3
    Inboard body flaps are done...had to dremel out a slot for the relocated control horn. As per BVMís manual. I ended up reversing the geometry from whatís shown in the video. Was getting some binding when retracted. By switching the throw direction I went from a constant 0.6 amp draw to 0.12 for both servos. All seen on the Jeti telemetry
ID:	17198   Click image for larger version.
  6. #26
    Received: 3
  7. #27
    Received: 3
    Fuel tanks plumbed...used Viton inside and the copper tubes so the clunks can’t get curled backwards inside the tanks. Tank fittings are from Dirk at Pacific RC Jets, nice bling...
    I’m going to leak check them pressurized under water, and then I’ll rinse them out with kerosene
ID:	17200   Click image for larger version.
ID:	17201   Click image for larger version.
  8. #28
    Received: 3
    Slightly off topic but I picked up a new transmitter off RCCanada, slight upgrade going to the DC-24....I like the feel of the tray radio plus it connects me to my European roots...😜
ID:	17203   Click image for larger version.
  9. #29
    Received: 3
    Got the nose gear doors converted from pneumatic to servo operated. I fabíd up some wooden servo mounts, made control linkages with 2-56 rod...
    Hysolíd into place for the night
ID:	17212   Click image for larger version.
ID:	17213   Click image for larger version.
  10. #30
    Member Dansy's Avatar
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Looking good....
    Daniel
