Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: BTE Reaction 54 on the home stretch in the build phase
    Senior Member KenPark's Avatar
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    OMG - Just keep sanding eventually it will look like the jet you always wanted
    Ok went and added over the wing Jet Intakes aka sorta of F-15 or Mig-ish
    Far from finished but I can see the end of the build is near
    Hope to glass the entire model
    Been thinking of a Fantasy Luft colors of what-if WWII continued with next gen of jets
    Cheers
    Ken
ID:	12899   Click image for larger version.
ID:	12900   Click image for larger version.
ID:	12901   Click image for larger version.
ID:	12902   Click image for larger version.
    Senior Member RC_MAN's Avatar
    Aug 2015
    Peter Doupnik
    Windsor Ontario
    Futaba 18 MZ, Jeti 24
    Received: 4
    Re: BTE Reaction 54 on the home stretch in the build phase
    Hey Ken you forgot to mention the Ottawa Jet Rally
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    Quote Originally Posted by RC_MAN View Post
    Hi Peter
    WE GOT 3 DAYS OF JET FLYING IN OTTAWA THIS YEAR!!!!!
    THURSDAY & FRIDAY 15-16 JUNE @ THE PHELAN RC CLUB THEN WE MOVE TO THE CARP AIRPORT FOR THE SATURDAY 17 TH JUNE (fathers day weekend)
    DON'T FORGET THE AIRPORT IS GIVING AWAY FREE JET-A TO THE PILOTS
    https://www.facebook.com/Ottawa-Vall...1575304535264/
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    The jet intakes came out nicely once I got some wall spackling filler all blended in and sanded
    The nose wheel hole in the bottom of fuse got a general cut-out to ensure I got the correct spot located - This way if I decide to upgrade to prolink struts etc I will have an easier time making adjustment with the landing gear.
    Their is a access hatch on-top of the fuse - the book shows this is to access the fuel shut-off value etc. I used rare-earth magnets to secure the hatch but added a fake antenna to use as a quick handle to pull it up - Works great
ID:	13019   Click image for larger version.
ID:	13020   Click image for larger version.
ID:	13021   Click image for larger version.
ID:	13022   Click image for larger version.
ID:	13024   Click image for larger version.
ID:	13025   Click image for larger version.
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    Got myself EZ-cote from Great Hobbies and started the process of glassing the model
    Today was step1 Laying on a 1st cote - used a foam-brush and thick coffee/style paper-cup Goes on nicely was able to cover one side then when done things were dry enough to do the other side. Nice!
    So today coated Tail feathers, Ailerons and the flap
    Senior Member JBajkor's Avatar
    Joe Bajkor
    Hamilton, Ont
    Looking great! I really like that model.
    Is there a path for air to flow from the nose gear opening to the engine? I ask because my PST reaction has that flaw. Flying from grass allows anything kicked up by the nose gear to get sucked in the engine. I see bits of grass in the fuselage and on the FOD screen after a flight. I'm sure some grass has gone through my engine. I plan to put a mesh barrier just behind the nose gear to prevent this in the future.
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    Nope there is no way for grass to travel through the fuse with all the bulkheads required to build the model.
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    Good day!
    Well the progress is slow but good! - Not rushing the glass job has produced a very smooth fuselage - Had a bit of trouble getting the wings back on today
    I think things shrank a tad when you add all that moisture back into the balsa. Just got the wings left to glass then I'll be ready for primer & paint.
ID:	13507   Click image for larger version.
ID:	13508   Click image for larger version.
    Ken Park
    Ottawa - Barhaven
    futaba
    Received: 11
    I ran out of fiberglass. Made an order with Thunderboltrc got 3/4 oz glass cloth
    While I was waiting used Hysol to glue the Horizontal Stab and Vertical Stab onto the model then when dry - slotted/hinged and glued in the Elevator & Rudder.
    I got the glass yesterday - So today I started on the top wing of the Reaction - I was able to do 1/2 the wing using a single piece of glass cloth. I love this Eze-Kote - so easy to use and the cloth simply pushed out flat with the use of a foam brush - No wrinkles - no mess - no smell
ID:	13700   Click image for larger version.
ID:	13701   Click image for larger version.
    Joe Bajkor
    Hamilton, Ont
    There is a really good place for all things fiberglass, carbon, etc. http://www.compositescanada.com/
    Worth checking out.
