Page 9 of 9 FirstFirst ... 789
Results 81 to 90 of 90
Thread: T-One build
  1. #81
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Received: 9
    Re: T-One build
    Quote Originally Posted by Dansy View Post
    Will start putting mine together shortly.....the Honda scheme, it look like a lot of fine to fly.
    Love the Honda scheme!
  2. #82
    Member Dansy's Avatar
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    One more project before starting on mine....
    Daniel
  3. #83
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    Started doing some work, I got the Electric Retract from the factory, but they donít quite fit, will need to sand down the ribs a little so they can sit on the rails.....
    Iím going to be an all Ditex servo build (Ditex is the Hacker servos) fully programmable...hopefully soon right from the Jeti TX with telemetry.....for the aileron and flaps they will require shimming to align with the pre-cut slot nothing unusual.
ID:	16484   Click image for larger version.
  4. #84
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    Well the build progress...change in equipment....
    Decided on
    K140G2
    MKS HBL960 Ailerons ans Elevators
    MKS 777 on Flaps and Ridder
    MKS 6125 mini gear door
    Ditex 1906 on Steering
    Electric retracts
    King tech smoke with Tam tube
    CB200 REX7A and R3 Jeti Batteries
    Intarco Fuel Stuff
    The Stabs/Rudder and Wings as done, starting on the aft fuselage...
ID:	17073   Click image for larger version.
ID:	17074   Click image for larger version.
ID:	17075   Click image for larger version.
ID:	17076   Click image for larger version.
  5. #85
    Brent Holmes
    Southern Ontario
    Received: 9
    Re: T-One build
    Decided on
    K140G2
    Electric retracts
    Intarco Fuel Stuff
    Sounds like a nice setup! You will be happy.
    I just changed out my 120 for a Kingtech 160G2. The 120 was ok, and it flew just fine, but I am looking for a little extra vertical power!
    I think that a 140-160 is the sweet spot with this jet. Might have to use a bit of throttle management in some areas. LOL!!
  6. #86
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    I didn't want to change my V3 pipe...so I just want it safe after all its not a speed freak plane.
  7. #87
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    Nose retract and nose door servo are in an programmed
    Pipe and Motor is in.....I also started planning the main board...but I'm still waiting for some order to come in.....to finish the aft section, wings/stabs/rud wires connections and main board parts like smoke pump and valve.
ID:	17156   Click image for larger version.
ID:	17157   Click image for larger version.
  8. #88
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    So the Fuel tank Tabs are glued and drill and fitted in the jet. Nose door servo is installed and programmed, the front corner of the door is sticking out a little, I will re-inforce that part to try to force the front to follow the fuselage shape...
    https://youtu.be/swsv20L6Ylw
    Put this jet aside, I'm still waiting for some parts to finish this one, starting on my DMP Ventrix
  9. #89
    Re: T-One build
    Looking good there Dan
  10. #90
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Re: T-One build
    Thank you, trying my best retirement projects
