Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
Thread: T-One build
    Member JimBrown's Avatar
    May 2015
    Jim Brown
    Rockland, ON
    T-One build
    While at Best In The West out in California in early October, I picked up a new T-One jet that I had ordered back in August. It managed to survive being in the back of my pickup for some 5,000 km. Definitely well packaged.
    Yesterday I finally had a chance to unbox it and have a good look at what I got. And I got a beauty. The build quality on this jet is outstanding. And the hardware package appears to have good quality stuff as well.
    Since my flying season is pretty much over, I'll be taking my time and building this one carefully. I'll post progress occasionally.
    ...jim
ID:	11830   Click image for larger version.
ID:	11831   Click image for larger version.
    Received: 198
    Given: 62
    Re: T-One build
    Very sexy there Jim
    Re: T-One build
    Beautiful! Orange presents so nicely against a blue sky or white clouds, it's a great colour for RC planes.
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Received: 9
    Re: T-One build
    Shweeet! I am keeping an eye on this thread.
    I have my name on the waiting list, but I don't have any idea when/where my name is on the order of shipments. Seems too good to be true for the price.
    What turbine are you planning to install??
    May 2015
    Jim Brown
    Rockland, ON
    Re: T-One build
    She'll be powered by a B100F from Peter at Altecare. I figure 27lbs of go should move a 27lb jet right along.
    This is my first jet with a strut mounted steering servo. I'm in love with that! So easy to set up.
    And yes, I've applied LocTite to all the bolts on the retracts, as well as slightly trimming the trunion locks.
    ...jim
ID:	11853   Click image for larger version.
    Senior Member Vettster's Avatar
    Received: 43
    Re: T-One build
    Its great looking jet and an even better looking price tag. Way to go Jim
    Simcoe Model Aircraft Club (SMAC) Our forum is here.. http://smac.freeforums.net/forum
    http://rccanucks.com/showthread.php?...5596#post15596 clubnomax
    If you do not have the time to do it right, where do you get the time to do it over?
    May 2015
    Jim Brown
    Rockland, ON
    Re: T-One build
    One thing RCPete and I noticed while messing around with his T-One at BITW is that the equipment tray is only supported at the ends. This allows the middle of the tray to bounce up and down just a bit. If you have a gyro on the tray, this could potentially have an adverse affect. So, I added a couple of rails for more support.
    ...jim
    May 2015
    Jim Brown
    Rockland, ON
    Re: T-One build
    While reading the forums and Facebook posts about the T-One, several people mentioned issues with servo horns and push rod installations. Here's my solution. Note that it does require widening the servo horn slot. Fortunatly, the holes already in the control surface horn are perfectly sized for the 4-40 bolt. I'm not using the supplied ball links, instead I'm using DuBro 4-40 ball links. The supplied ball links appear to be for 3mm threaded rod while the supplied rods appear to be 2.5mm or 2mm. They simply slide in and out of the supplied ball links, however they fit the 4-40 ball links nice and tight.
    ...jim
ID:	11861   Click image for larger version.
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 514
    Given: 502
    Re: T-One build
    purdy
    May 2015
    Jim Brown
    Rockland, ON
    Re: T-One build
    Would anyone know where I could order some 90 degree elbow barb fittings to replace these ones?
    Thanks,
    ...jim
