Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 158
Thread: Aura FC8 Reference Library
  1. #81
    Received: 77
    Re: Aura FC8 Reference Library
    More amazing things this gyro can do. Imagine a fly by wire mode where you can set the parameters of how you want your plane to behave when you're flying it. The tradition gyro "Rate Mode" is a "Rate of Change" buffer. The other one detailed below is much cooler.
    "Rate Command" is used if you want the plane to behave exactly the same all the time, example, if I set the "Rate Command" for the Ailerons to 360 degrees / second. Regardless of how much or how little throw I program into the Aura, the gyro will move or deflect the surfaces and make the plane rotate at 360 degrees / second.
    In the old Pattern Days, there as a maneuver for 3 rolls in 5 seconds, so how you'd do that is to divide 360 x 3 / 5 = 216 per second then put that number into the Rate Command mode for the gyro and your plane will rotate that amount all the time at full deflection. Here's the added bonus, the rudder and elevator input is done automatically too, just like heading hold mode, but without the funny Heading Hold weird actions.
    Yes, need more data in the FAQ and so forth. Basic information is available in the Aura Config tool by Mousing Over the related terms and fields.
    Here is a Cross Posting from the other Forum....
    Thanks!
    RATE COMMAND
    Hi Joe,
    Perhaps a difficult topic to communicate, but hopefully possible if one already understands the basics as a foundation.
    Much of the documentation is built into the Config Tool.
    If you 'mouse over' the various settings in the Config Tool, you will get a pretty good feeling for the 'what and how'..... (and some more over the 'rate command' word in pull-down)..... as to the when and why, I will try to fill in a bit more. Frankly, there has not been a lot of user interest up till now, so feedback has been minimal.
    Basically there is no stick priority in rate command, it has full gain across the pilot input, but it does not 'damp' all motion to 'none', instead, it uses the gain to try to drive the 'rotation' to a rate of rotation' based on the pilot input.
    With this, you can see the settings and how they work.
    The Rate Gain is Aura's magnitude of input to 'track' the commanded rotation rate. on the same scale as the Rate Dampener, so start with a similar setting here. (Will oscillate if too high as is normal)
    The Feed Forward Gain is how much direct pilot surface command movement (aileron for ex) is put-in that the user feels should provide the desired and set rate of rotation. Experience says 70% is often a good ballpark number if the settings are appropriate for the models capabilities. (Surfaces may move a little less than you are used to as Aura will add to this if not rotating at commanded rate)
    The Max Rate is the rate of rotation desired in that axis at full stick deflection (ex roll at 360 degrees per second). It will be proportioned by stick input from Zero (stick center) to Max Rotation Rate (full stick deflection)
    The Defaults are certainly safe places to start with many models.
    Some Tips:
    Start with Rate Command on axis in one flight/control mode. Strongly suggest Aileron as it will be the most natural feeling.
    Suggest when you are comfortable, for experimentation/testing purposes, use the transmitter expo some for quick adjustments of that feeling.
    The controls will feel a bit 'different' and require some user expectation adjustment.
    Use caution on rudder and elevator especially if you have a plane that is prone to tip stalls or the like as user inputs can be amplified more as the vehicles are typically NOT free to rotate on these Axis.
    Ailerons should feel most conventional, and since the Aura will now try to track a roll rate in real time (no integration over time), your roll rate will be much more constant in the face of varying airspeed and 'load'. This can be helpful when doing (or learning) harrier rolls and things like that. It will generally make things more consistent.
    If you use on Elevator and Rudder on a plane like the QQ Extra, and say you are 'harriering, hovering, torquing'... expect the controls to feel much more Powerful around center (at first you might think 'sensitive', but strangely very well damped as well!).
    Why?... Say the plane is yawing left... as the un-commanded rate increases, increasing correction is made by Aura to compensate.... if the pilot then gives the proper correction, this is ADDED to Aura's command, and Aura's command is not reduced by stick priority... it is full gain, AND commanding Aura to rotate the other way, so Aura's correction is increased by kind of a square function since it is now rotating the wrong way as commanded, and the users correction is summed with all this via feed forward! This makes the controls VERY powerful in making Corrections, but still quite subtle and damped when all is correct (much smaller corrective inputs will be needed). Expo can adjust this, but it will always 'feel different' on rudder and elevator in particular (because it is different). Kind of a power steering when fixing 'errors'.... (but it does not correct (in a heading lock sense) or fly for you.)
    A different feeling, but probably in a couple of flights one will start to get the 'feeling' for it. I really liked it once I had the feel for it in applications like normal flight, harriers, torques, etc.... Just very powerful yet oddly subtle controls.
    Because of this additive control, be careful on planes that have tough stall characteristics.
    Because the gain does not decay and Aura's commands are added to the Pilots, it can be quite possible to 'overdrive' the servos and damage them or the linkages. Use the Min/Max Servo Pulse Width settings on the Servo Ports Tab to adjust the servos limits as needed to protect things.
    For 'Aerobatic/3D' flying and aggressive/advanced flying with snaps and so forth, Rate Command will likely never be an 'always-on' one-stop solution. Because the gain does not decay, the gyro is very much in the loop. If you set the Max Rates high enough to command the type of 'snap' or 'waterfall' you want, it will likely always feel too 'hot'. One could try two rate command modes with high and low Max Rates, but one may be better with rate command for some maneuvers and rate dampener for others.
    Rate Command has some of the positive aspects of 'heading lock', but without some of the negative aspects, as it has no time component, no memory... It just tries to make the vehicle rotation rate more as-commanded in real-time, regardless of stick position!
    Hope this Helps,
    David
  2. #82
    Member
    Mar 2016
    Bob Austino
    Taranis
    Have you flown this yet Joe?
  3. #83
    Received: 77
    Quote Originally Posted by bob_nj View Post
    This weekend I'll try it out on the Ailerons.. then I'll configure rudder and elevator at 3 mistakes high to see how it feels.
  4. #84
    Member
    Mar 2016
    Bob Austino
    Taranis
    Cool!
    We expect a full report in the morning
  5. #85
    Received: 77
    I've decided to split the config on my Yak54, attached is the new file:
    I'm using the radio for triple rates / expo / throws
    Using the Aura for Master Gain and Aura Flight Modes
    Attached Files Attached Files
  6. #86
    I got the Aura setup to my liking on a Habu32x with my Jeti radio. Thanks to JoeT for the help.
    Just a basic setup with 2 flight modes for the moment (gyro off, stabilization with a rotary dial to adjust the gain) for me to learn the gyro. Something similar to what I'd do with an iGyro or Cortex.
    Once happy with the gain, I plan to add in flap-crow and flap-elevator mixing via the Aura instead of how I currently have it setup via Tx.
  7. #87
    Received: 77
    Glad you did like I did and got over the fear of opening the box. Flap Crow and Flap elev mixing should be cool!!
    Congrats.
  8. #88
    Question... what is "stick priority"
  9. #89
    Received: 77
    Stick priority is a setting that's used to let Aura know when to hand control onto the user.
    If the stick priority is set to 40% for example.
    Aura is active until 40% stick movement then from 41% to 100% aura control is gradually tapered off.
    Typing this from my phone, excuse the typos.
  10. #90
    Quote Originally Posted by JoeT View Post
    Joe, it's just a little different than that. If you had stick priority at 40% your gains would reduce proportionate to stick movement until 40% at which time the gain would become 0 and stay that way to 100%.
    I for example like my stick priority around 90% or so, that way if I use a little transmitter trim the stabilizer will still be off for any axis with the stick at 100%. That said, if you had stick priority at 100% and the stick was at 95% you would only be running 5% of your gain setting anyway...I think most of us could just leave it at 100% and notice very little impact.
    I believe 'stick priority' is the innovation that allowed stabilizers to be used for 3D...tumble type maneuvers wouldn't work very well otherwise. I'm pretty sure this was the innovation that allowed the Demon Cortex to be marketed for use in 3D, it just isn't adjustable on the Cortex.
    Anyway, the wiki explains it better than I can: http://wiki.flexinnovations.com/wiki...w_is_it_set.3F
