Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 138
Thread: The birth of Solstice (build thread)
    Senior Member JBajkor's Avatar
    Joe Bajkor
    Hamilton, Ont
    Re: The birth of Solstice (build thread)
    It's not going quite as fast as the posts make it seem. I have been working on this for a month, just got around to posting it now.
    I am at the least enjoyable part of the construction now: put filler on, sand it off, put more on, sand it off, put more on, sand it off... Will this ever end? The nose is about 3" shorter than planned. Broke it off while moving around and decided to leave it like that. I have to keep reminding myself that this is only a test model and not the final version. (must keep OCD in check)
ID:	7840   Click image for larger version.
    Joe Bajkor
    Hamilton, Ont
    Carved and smoothed the bottom. Pics don't show the number of hours involved.
    Joe Bajkor
    Hamilton, Ont
    Working on the rudder while primer or filler dries. This is the servo mount. Just making it up as I go, don't have plans for all the small details.
    Posting is all caught up with construction so things will seem to go a lot slower now.
ID:	7843   Click image for larger version.
    Senior Member DHC8's Avatar
    Louis
    Limoges
    Very nice! I wish I had the time/patience/skill to build from scratch... Mostly the time though.
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
    Joe Bajkor
    Hamilton, Ont
    I got a cheap motor & fan assembly and it did not have any mounting tabs. Mounted the thing in a jig, covered it with saran wrap, then put 6 layers of glass. Ended up with a fan mount.
ID:	7887   Click image for larger version.
ID:	7888   Click image for larger version.
    Joe Bajkor
    Hamilton, Ont
    Remember that servo mount for the rudder? Here it is with servos mounted. Can you guess why 2 servos? The few people that know about this are not allowed to guess!
    Joe Bajkor
    Hamilton, Ont
    forgot the picture...here it is.
    Senior Member Vettster's Avatar
    Received: 43
    Nice work on the EDF mount Joe.
    Im guessing the Rudder is Split so as to act as an airbrake? Sweet if so.
    Trevor
    Simcoe Model Aircraft Club (SMAC) Our forum is here.. http://smac.freeforums.net/forum
    http://rccanucks.com/showthread.php?...5596#post15596 clubnomax
    If you do not have the time to do it right, where do you get the time to do it over?
    Joe Bajkor
    Hamilton, Ont
    Quote Originally Posted by Vettster View Post
    Trevor
    First guess got it right!
    Flaps on a canard are equivalent to down elevator. It would require a dramatic increase in canard pitch to compensate. The split rudder has a very high drag line causing pitch up. Also, the rudder hinge line is tilted back about 20* giving up elevator effect. Dropping flaps should balance the split rudder. This being a test model, will allow me to adjust mix between flaps and rudder split without risking the turbine.
    Received: 43
    Yikes! Im happy for your sake that your doing a smaller test model first.
    Joe do you fly at the Burlington Club with your large scale helis?
